Difference Between UDF and Expressions in Thermal Comfort Evaluation? |
Rep Power: 7 ![]() |
Good day,
I am conducting evaluation of cabin thermal comfort inside passenger bus using PMV equation from ISO 7730 standard. At first I'm gonna use UDF but a friend of mine told me that I can use expressions inside the Fluent post-processing program. However, I'm not sure what are the differences between those two in evaluating thermal comfort. Is it okay if I use expressions instead of UDF? What are the differences between those two? |
Alexander
Rep Power: 34 ![]() ![]() |
Fluent post-processing program means post processing
UDF may influence (or may not) solution. If your goal is a combination of variables, which are calculated by default -> you may use expression instead of UDF best regards |
Dear AlexanderZ, thank you for the explanation
Mohammed Khan
Rep Power: 6 ![]() |
Hi..
Actually, I too need to work on the similar analysis, (thermal comfort). I got one extension(of thermal comfort) from Ansys website, unfortunately that isn't working out. Can you suggest me about the expression thing. I'm new to Ansys fluent, unable to catch up.. Any help, I will be really thankful. Thank you Cheers Mohammed. |
#5 | |
Moe
Rep Power: 5 ![]() |
Mohammed Khan
Hi.
The extension doesn't work. I finally created custom functions. I investigated PMV, PPD, Pd, Age of Air. All of these using custom functions. Thanks Mohammad Email - aven.farhan@gmail.com |
#7 | |
Moe
#8 | |
Ho Chi Minh
Rep Power: 0 ![]() |
ldhuy.simeon@gmail.com Thank you. |
expressions, pmv index, post-processing, thermal comfort, udf |
