MPI Application rank 0 exited before MPI_Finalize() with status -1073741819
Old   April 27, 2019, 21:07
Default MPI Application rank 0 exited before MPI_Finalize() with status -1073741819
Minnesota
zjuv9021 is on a distinguished road
Hi all,
I'm doing an FSI with system coupling and after a certain point in the run it gives out the following:
" Reversed flow on 40 faces (3.7% area) of pressure-outlet 5.
! 1693 solution is converged
1693 8.9890e-04 6.9204e-07 1.1039e-06 1.3291e-06 1.3521e-05 2.1101e-05 1.8513e+03 5.6139e-08 0:00:41 29
Flow time = 1.5399989s, time step = 154
Exchanging Data... done.
Writing "| gzip -2cf > C:\Users\juvelj1\AppData\Local\Temp\FSI Run 2.tmp\FSI Run 2_files\dp3\FFF-2\Fluent\FFF-2.1-11-00154.cas.gz"...
Writing temporary file C:\\Users\\juvelj1\\AppData\\Local\\Temp\\flntgz-402124 ...
139587 hexahedral cells, zone 12, binary.
139587 cell partition ids, zone 12, 4 partitions, binary.
412498 quadrilateral interior faces, zone 7, binary.
483 quadrilateral pressure-outlet faces, zone 5, binary.
11560 quadrilateral wall faces, zone 6, binary.
483 quadrilateral pressure-inlet faces, zone 18, binary.
146160 nodes, binary.
146160 node flags, binary.
Done.
Writing "| gzip -2cf > C:\Users\juvelj1\AppData\Local\Temp\FSI Run 2.tmp\FSI Run 2_files\dp3\FFF-2\Fluent\FFF-2.1-11-00154.dat.gz"...
Writing temporary file C:\\Users\\juvelj1\\AppData\\Local\\Temp\\flntgz-402125 ...
Done.
step flow-time report-def-1 flow-time
154 1.5400e+00 1.8513e+03 1.5400e+00
COUPLING STEP = 155 COUPLING ITERATION = 1
The fl process could not be started.
SC Fluent encountered fatal error. Saving case/data file....Done.
Deleting Client...done
Shutting down Server...done
===============Message from the Cortex Process================================
Fatal error in one of the compute processes.
Does anybody know what this is trying to tell me? Is it related to actual convergence of the fluid or unrelated?
Regards,
Zach
zjuv9021 is offline   Reply With Quote
Old   April 29, 2019, 02:06
Lucky
It converged and successfully saved. Fluent did its thing. It tried to do the structural coupling part and something died.
mpt_connect: errorThe fl process could not be started. MPI Application rank 0 exited tjZDH FLUENT 3 November 28, 2021 15:30
CentOS kernel update 3.10.0-862.11.6 breaks MPI Michael Rath CFX 0 August 22, 2018 10:10
MPI application rank 0 exited before.. jypark FLUENT 1 July 15, 2016 13:58
MPI Application rank 0 exited before MPI_Finalize() with status 1 mustafadeniz89 AVL FIRE 6 November 24, 2015 10:40
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 15:53
