Average study of RANS results
Old   April 26, 2019, 07:23
Default Average study of RANS results
serrar is on a distinguished road
Hi expert,
I recorded .data and .cas files of a turbulent flow with a RANS model and transient every 10-time steps. Now, I want to do an average study of these files, for example, 10 files per post-processing.
is it possible?
Best regards,
serrar is offline   Reply With Quote
Old   April 26, 2019, 10:48
Lucky
Yes and no.
Yes: you should have activated the data sampling for time statistics option before you did the simulation.
No: you can't do it after the fact. You need to re-run it. Or you write your own code that does the averaging.
Old   April 26, 2019, 11:07
Dear LuckyTran,
For this answer how can I do these steps using FLUENT?
Best regards,
Old   April 26, 2019, 11:31
Lucky
In the GUI, in the same place where you can find the calculate button.
There is a checkbox.
Google is your friend.
Old   April 26, 2019, 11:57
Dear LuckyTran,
Thank you very much for your quick response, which allowed me to start my studies. If possible, I need more details. I have :
My time interval [0, 0.3] and I want to save the values ​​every 10 steps with:
time step size = 5e-5
Number f time step = 6000
What good values ​​can I have in:
sampling Interval?
Sampling option?
Best regards,
Old   April 26, 2019, 12:10
Lucky
sampling interval 10 means it adds the values to the average every 10 time-steps
sampling options are options. If you want to use them, you can use them. If not, don't.
Read the guide!
Old   April 26, 2019, 13:23
Dear LuckyTran,
I followed your advice, but after which iterations the code that diverges. Do you have help to dislodge the situation?
Divergence detected in AMG solver: x-momentum
Divergence detected in AMG solver: y-momentum
Divergence detected in AMG solver: pressure correction
Divergence detected in AMG solver: k
Divergence detected in AMG solver: omega
reversed flow in 49 faces on pressure-outlet 7.
Error at host: floating point exception
Error at Node 0: floating point exception
Error at Node 1: floating point exception
Error at Node 2: floating point exception
Error at Node 3: floating point exception
Error: floating point exception
Error Object: #f
PHP Code:
[ATTACH]69630[/ATTACH]
ATTACH]69631[/ATTACH
post procesing
Real results from a simple study WHAT am I doing wrong? jon g FloEFD, FloWorks & FloTHERM 5 November 14, 2018 10:46
Results from RANS and LES look completely different ssa_cfd OpenFOAM Running, Solving & CFD 7 September 27, 2018 08:17
Comparing Air numerical results with water experimental results cristian2009es Main CFD Forum 1 July 2, 2014 19:11
RANS from time average -- How about space average? TT Main CFD Forum 1 April 11, 2006 15:38
Listing Average Results Deepak Siemens 2 March 14, 2006 02:22
