April 22, 2019, 12:39 |
heat transfer coefficient
Rishabh
Rep Power: 7 |
So I am interested in finding heat transfer coefficient in a cutting tool with a constant heat source(one small section at constant temperature) .The air is being flown over the tool at a speed of 1m/s. In the attached image one can see that a small cut face(I named it as nose section) is kept at constant temperature of 1057K. I have used the nose section as wall with constant temperature and all other interfaces that are coming in contact with air are taken as coupled walls.
Temperature distribution is being calculated correctly but contours of heat transfer coefficient are always showing zero. Also if using heat flux on nose face/(Ts-T∞) is giving abnormally high values. Is there a other method to calculate heat transfer coefficient? I think boundary condition at nose and its interface with fluid has some mistake! |
Interphase mass transfer of a reaction | cfx_ws1992 | Main CFD Forum | 0 | May 15, 2017 21:42 |
Surface Heat Transfer Coefficient CFD Post | MJ1105 | Visualization & Post-Processing | 0 | February 19, 2016 04:57 |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 17:00 |
Heat Transfer Coefficient in Compressible Flow 3D turbine cascade | Karkoura | CFX | 0 | March 10, 2011 15:35 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
