How to change LED beam angle properties in fluent radiation BC? |
April 21, 2019, 03:36 |
Lokesh Dhake
Rep Power: 10 |
I am performing DO radiation model with LEDs in the system. If my beam angle is 60 degrees, then how should I change the given beam width? Is there any relation between given beam width (which is solid angle) and normal beam angle?
Is there any impact of beam direction on radiation model? because when I changed it and checked I got almost same results. |
beam width, irradiation, led, radiation, radiation do model |
fluid fluid radiation properties | IronLyon | CFX | 5 | March 18, 2019 16:40 |
log-law change - Fluent | C.C | FLUENT | 1 | November 5, 2012 09:25 |
Fluent is not accepting Modification in Material properties | er.mkumar | FLUENT | 0 | September 1, 2012 14:24 |
Chemical properties that are used in Fluent | kimej | FLUENT | 4 | August 19, 2011 11:29 |
Fluent incident radiation problem | Michael Schwarz | Main CFD Forum | 0 | October 21, 1999 05:56 |
