Tracer Injection and Mass Fraction Analysis
Old   April 18, 2019, 00:02
Question Tracer Injection and Mass Fraction Analysis
Gustavo Henrique
Gbox.br is on a distinguished road
Hello everyone!
My question is simple. I'm realizing studies on a water storage tank, and I would like to make a tracer injection in the tank, but I'm having some troubles with that. First of all, every paper, answer and tutorial that I found said that first it is necessary to resolve te flow field in steady state and then turn on the species transport (I set the dye with the same characteristics of the water inside the tank). HOWEVER, the results aren't like I expected, it seems that there was nothing tracked, even if I've setted the inlet with some mass fraction of the species and set everything like my references said.
So, I would like to know if someone could helps me or show some troubles that I could have been made and it is usual on this process in particular?
Thanks!!
Gbox.br is offline   Reply With Quote
storage tanks, tracer, water
Match Pressure Inlet/Outlet Boundary Condition Mass Flow Rate MSchneid Fluent UDF and Scheme Programming 3 February 23, 2019 07:00
file injection.: continuity fail; volume injection.: wrong total mass blerli_91 Fluent Multiphase 6 October 2, 2018 06:34
Inconsistencies in reading .dat file during run time in new injection model Scram_1 OpenFOAM 0 March 23, 2018 23:29
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
How to obtain the mass fraction of evaporated diesel spray Mnzki FLUENT 0 June 17, 2012 17:22
