Zero normal temperature gradient boundary condition |
April 13, 2019, 12:21 |
jgs
Rep Power: 7 |
Hello
I am simulating a flow through a square section tube and I have to put dT / dx = 0 as a boundary condition at the output face (normal x-axis to the output face). Any of the predefined Fluids B.C. satisfy this condition dT / dx = 0 ?? I am looking for it in the Ansys manual but I do not find anything. Thanks in advance |
April 15, 2019, 13:48 |
Lucky
Rep Power: 66 |
dT/dx = 0 means streamwise gradient is 0?
The outflow boundary condition makes the diffusive flux 0, which is equivalent to a neumann type BC in many scenarios. Most of the outlet type boundary conditions can also be used this way (by going to expert settings and disabling diffusion at the outlet). Fluent doesn't give you the option to hard clamp the streamwise derivative to be 0. |
April 16, 2019, 05:19 |
jgs
Rep Power: 7 |
Thank you for your answer.
How can I do that? Disable diffusion in the experts settings?? |
April 16, 2019, 15:24 |
Lucky
Rep Power: 66 |
Just use the outflow boundary condition?
April 18, 2019, 03:53 |
jgs
Rep Power: 7 |
Ok. I am performing an unsteady state simulation with the boussinesq aproximarían for the density. I have seen in the ANSYS manual:
Note that outflow boundaries cannot be used in the following cases: • if a problem includes pressure inlet boundaries; use pressure outlet boundary conditions (see Section 6.8) instead • if you are modeling compressible flow • if you are modeling unsteady flows with varying density, even if the flow is incompressible Regarding the last point, I am not sure if I can use this B.C. Is it correct if I use it? I have another doubt. Outflow B.C. impose dP/dn = 0?? Zero Pressure gradient?? I need to implement this boundary condition Last edited by 15326_jgs; April 18, 2019 at 08:56. |
April 20, 2019, 11:51 |
Lucky
Rep Power: 66 |
None of the boundary conditions except the wall boundary condition impose the dP/dn = 0 condition. It physically makes no sense to use this condition except when there is a wall and hence it is not programmed. Mathematically it makes sense as a constraint, but physically no and it results in ill-posed problems. At a non-wall boundary, you have flow...
January 5, 2020, 00:22 |
#7 | |
Jerry
Rep Power: 7 |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 01:00 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
How to get free stream temperature in boundary condition | saharesobh | FLUENT | 0 | October 9, 2012 18:12 |
(Heattransfer) Temperature boundary condition problem | suitup | OpenFOAM Bugs | 15 | October 14, 2010 23:18 |
