How do I increase the quality of the resulted video from Ansys Fluent simulation? |
April 10, 2019, 13:47 |
Kristián Azor
Rep Power: 7 |
Hey! I am working on a flow analysis over a 2D airfoil.. I simulated the situation at different angles of attack, put it at 400 interations and everything works well in programme, although after when I check the video of it in a file, it has a very poor quality, I cannot even read the scale... Does anyone know how to improve the quality of a video? Thank you
April 18, 2019, 11:26 |
Pramod Narayan
Rep Power: 12 |
Hi Kiko,
If you have license for ANSYS EnSight, then you can do post processing with EnSight to obtain very high quality animations. Remember to export the data in EnSight case gold format for faster processing. If you have to use Fluent to create animations, I would recommend saving pictures at specified time steps or iterations using Auto Export and then combining the images using a tool like FFMPEG. I have obtained some good quality animations using this method. Good Luck. |
quality, video animation |
Fluent in Ansys Workbench : Change Working Directory | sral | FLUENT | 4 | March 29, 2019 11:29 |
Start new Ansys Fluent Simulation automatically | Malue | Fluent UDF and Scheme Programming | 1 | October 4, 2017 02:48 |
Surface ablation simulation in ansys fluent | Swathikr | FLUENT | 0 | May 30, 2016 04:52 |
Propeller flow simulation in Ansys Fluent | a1ananth | FLUENT | 2 | December 4, 2014 16:30 |
few quesions on ANSYS ICEMCFD and FLUENT | Prakash.Paudel | ANSYS | 0 | August 12, 2010 13:07 |
