April 7, 2019, 18:35 |
micro-combustion with solid phase
Weiqiang Liu
Rep Power: 9 |
Hi all,
I am doing a micro-channel combustion with fluent. I can get reasonable results without solid wall computation domain. However if I include solid computation domain, problem occurs. My problem is that the maximum temperature in the channel is always equal to the ignition temperature. For example, if I set the wall temperature (1400K) as ignition temperature, then the final maximum temperature will be 1400K. If I set the wall temperature (900K), then the maximum final temperature would be 900K. By the way, I ignite the mixture by first giving a high enough temperature to the wall then setting the interface wall as coupled. This is obviously not reasonable. Do anybody know what is the most possible reason for this? Best. Weiqiang. |
ignition temperature, maximum temperature, solid domain |
Solid combustion problem.... | godspeedsam | FLUENT | 3 | May 24, 2022 05:29 |
Model two phase system of water and solid particle using twoPhaseEulerFoam | Jack_Kerouac | OpenFOAM Running, Solving & CFD | 7 | January 28, 2018 03:43 |
Combustion of solid fuel | Dermer | FLUENT | 0 | May 30, 2017 12:03 |
alphaEqn.H in twoPhaseEulerFoam | cheng1988sjtu | OpenFOAM Bugs | 15 | May 1, 2016 17:12 |
energy from solid fuel combustion | Silvia | FLUENT | 1 | August 3, 2005 14:23 |
