Is there any way to see time step in the temperature contours?
Old   March 30, 2019, 00:17
Default Is there any way to see time step in the temperature contours?
Aja
aja1345 is on a distinguished road
I am simulating a transient model in ansys Fluent Separately(not from workbench). Now I want to export temperature contour in different time steps, But I can't create(or see) results with time step. Is there any way to see time step in the temperature contours?
I am grateful that guide me in this case.
Thanks.
aja1345 is offline   Reply With Quote
Old   March 30, 2019, 16:42
Lucky
Do you want time-step or flow-time? Because isn't there a window that always displays the flow-time?
There is an example here of how to create annotations to show the flow-time but usin cx macro's that I don't like. You can just replace flow-time by time-step if that's what you want. The idea is create an annotation that displays the variable. However, the annotations are static and so you must use the execute commands to update the annotation every time-step.
Old   April 1, 2019, 11:20
Moritz Kuhn
MKuhn is on a distinguished road
In Ansys 19.1 go to the tab "Viewing" --> first section "Display" --> Options and then under Layout tick the box "Titles". Then you will get the flow time (not time step) in the plots (only for transient solver). If you want to export contours for different time steps you have to save data files for these time step or you can use the "Solution Animation" to produce the plots during the solution process (faster and with less data usage)
MKuhn is offline   Reply With Quote
bash script for pseudo-parallel usage of reconstructPar kwardle OpenFOAM Post-Processing 42 May 8, 2024 00:17
Time Step Continuity Errors simpleFoam Dorian1504 OpenFOAM Running, Solving & CFD 1 October 9, 2022 10:23
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 06:28
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 08:47
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
