Slowing increase pressure inlet to get steady-state convergence? |
March 29, 2019, 15:13 |
OH
Rep Power: 7 |
Hi folks, I'm assessing the steady state condition of a primary and entrained flow in a pipe using Ansys Workbench with Fluent (v19.2). If I initialize (default hybrid initialization) with my primary flow at my desired pressure (2,000psi), the solution diverges. However, if I initialize at a 1,000psi BC, execute, let the solution converge then double the pressure inlet to my desired value and continue the calculation, then I get good convergence. I've tried a number of things (I'm very untrained with CFD mind you) including solution steering and have not been able to get convergence right off the bat.
In exploring the manual, I found that under "Calculation Activities" there seems to be a way of adjusting the inputs midway through the execution. Anybody have a hint on how I could change my pressure inlet value BC. I want to avoid the "man-in-the-loop" as I'm hoping to do a design optimization study involving a couple hundred iterations. Again, its steady state so the fact that I'm having this issue may be caused by something else. |
March 29, 2019, 17:05 |
Lucky
Rep Power: 66 |
You have to learn the text commands (the TUI commands). Press enter to see all available TUI commands.
A faster way might be to google/search for a Fluent journal file to get some ideas on what these commands might look like. It will look something like: /define/boundary-conditions/ blah blah blah Yet another way could be to just record a macro. |
Pressure Inlet VS velocity Inlet difference | Mohsin | FLUENT | 9 | January 4, 2021 11:34 |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 18:00 |
Pressure Inlet: question about total pressure | I-mech | FLUENT | 0 | July 13, 2014 06:38 |
Pressure Inlet Boundary Condition Issue | zoeburton1987 | FLUENT | 0 | May 15, 2012 10:20 |
error message | cuteapathy | CFX | 14 | March 20, 2012 07:45 |
