Airfoil simulation not working at certain angles of attack
Old   March 27, 2019, 19:47
Default Airfoil simulation not working at certain angles of attack
Mikiel
mabe20 is on a distinguished road
Hi all, I am currently trying to validate the Cl and Cd for a NACA 0020 airfoil, modeled in 3D.
My problem is that at an angle of attack of 2 degrees, the lift and drag forces are coming double of what they should be, as per the experimental data I have. When tested on angles of 0 4 6 8 and 10 degrees, the produced values are all within 5 % of the experimental data. At 12 degrees, the values are very high again.
I am using duplicates on the fluent setup so nothing should be changing, does anyone have any idea as to the issue.
Y+ values at airfoil surface are between 0.5 and 1.5 so these are also good.
I am using a structured mesh through ICEM and using k-e realizable with enhanced wall treatment. The mesh is decent quality except for about 0.001 % which are showing high skewness, but are located in irrelevant locations far from the airfoil, and are in no way effecting convergence (solution converges after around 60 iterations)
Note: tried using k-w SST also, but still got the same as the k-e model.
Don't know if anyone has experienced the same problem.
Thanks for any help
Mik
mabe20 is offline   Reply With Quote
airfoil 3d, fluent
Need help for the 2D airfoil simulation using OpenFoam losiola OpenFOAM Running, Solving & CFD 0 October 10, 2018 11:22
Airfoil 2D cfd simulation Cocorito90 OpenFOAM Running, Solving & CFD 14 December 19, 2016 04:43
Trying to perform test validity of Fluent with simulation of 2D airfoil didiean FLUENT 39 December 5, 2015 14:31
[CFX,ICEM] Simulation of wing / airfoil profile - pyramid elements, angle of attack Jonas_mm ANSYS 2 November 4, 2011 04:26
Airfoil Simulation for Validation Purposes Angela Bong Main CFD Forum 7 September 13, 2006 14:04
