March 18, 2019, 06:04 |
Perturbations of inlet for LES simulation
Rep Power: 9 |
Hi there,
I am simulating a supersonic flow case with a flat plate of zero angle of attack using Large Eddy Simulation (LES). I would like to reproduce the solution from a paper, in which the boundary layer of the flat plate follows a laminar-transition-turbulent pattern. Since this is a supersonic case, I would like to use density-based solver and WALE is chosen as the subgrid-scale model. As is described in the Help that perturbations could be assigned to the inlet for the LES model, I do successfully find the option of "Fluctuating Velocity Algorithm" for Velocity Inlet type boundary while using pressure-based solver. However, this option disappears when I switch the solver to the density-based one. Do you have any solution to this problem? Or does anyone has other methods to assign the turbulence intensity at the supersonic inlet while running LES? Regards. |
fluent, les, supersonic inlet |
Simulation of ball-valve opening w.r.t to varying inlet pressure | wasim_03 | Main CFD Forum | 1 | January 6, 2018 13:40 |
Pressure input for Velocity Inlet in middle of 2D transient Simulation | Shekhaai | FLUENT | 1 | August 30, 2016 23:43 |
VOF models on venturi scrubber simulation | toda | FLUENT | 3 | June 2, 2016 13:51 |
non-uniform inlet velocity simulation in Fluent 13.0 | shuminhua | FLUENT | 2 | October 27, 2013 20:17 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
