March 15, 2019, 22:57 |
ratio of catalytic to geometry surface area
Weiqiang Liu
Rep Power: 9 |
Hi all,
I am doing a micro-channel catalytic combustion simulation of methane. In my model the wash-coat domain of catalyst is not drawn, namely diffusion limitation is not modeled. My problem is I don't know how to define the parameter of 'ratio of catalytic to geometry surface area'. The default value in fluent is 1 and I believe actual value of this parameter should be much bigger than 1. I read a lot of related literature. Seems like those authors never mention what this value is in their model. I am wondering how to set this value in catalytic channel flow simulation. Can anyone help? Weiqiang. |
catalytic, geometry, surface ratio |
Calculating surface area in Axisymmetric simulation | cwl | STAR-CCM+ | 2 | February 16, 2022 09:51 |
Problem with divergence | TDK | FLUENT | 13 | December 14, 2018 07:00 |
[snappyHexMesh] How to add layers on the whole geometry surface | meithid | OpenFOAM Meshing & Mesh Conversion | 1 | January 24, 2017 06:41 |
Monitor surface area of an oil slick floating on water | visitor | FLUENT | 0 | November 3, 2014 10:53 |
Cross section and surface area factor | Fabiana | CFX | 0 | January 10, 2006 00:51 |
