Writing report files and creating report definitions.
Old   March 13, 2019, 17:20
Post Writing report files and creating report definitions.
Lisa
cfd_worker99 is on a distinguished road
I am solving a transient heat transfer case in fluent and ran into a small but extremely annoying impediment with regard to Post processing in Fluent.
I have setup a number of planes (300 in total). I calculate the area-weighted average temperature on each of the planes. As setting up individual monitors at each of these planes will be cumbersome, I use report definitions and then have these compiled in report files which are then generated as .OUT file.
It was all working perfectly, but for some reason, after the 1423 timesteps, the file stopped recording. The solution files still went On and the data files were saved but not the .OUT files.
I am now trying to fix this but so far nothing is working. I am able to create individual monitors and store them but the reports file just do not get recorded. Can you please help. :-(
cfd_worker99 is offline   Reply With Quote
Old   March 13, 2019, 21:33
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you may try to change .out to .dat =)))
it is possible to write scheme code to write data in file
best regards
AlexanderZ is offline   Reply With Quote
Old   March 14, 2019, 11:00
Moritz Kuhn
MKuhn is on a distinguished road
That is strange. Try to find out if it is a size problem. Split it in two files or write the data only every second time step. I record data over 5000 time steps (but not 300 planes) in *.txt instead of *.out and it works. But I think it has nothing to do with the file extension.
MKuhn is offline   Reply With Quote
Old   June 12, 2020, 13:55
Ketaki
kjoshi2 is on a distinguished road
I am having same issue while fluent writes .out report files.
@ cfd_worker99 - were you able to solve it? was it some size issue?
kjoshi2 is offline   Reply With Quote
post-process, report files
[mesh manipulation] How to write cellSet for different regions in constant/polyMesh/sets Struggle_Achieve OpenFOAM Meshing & Mesh Conversion 3 June 17, 2019 10:29
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! divergence OpenFOAM Meshing & Mesh Conversion 0 January 23, 2019 05:17
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 10:28
UDF issue MASOUD Fluent UDF and Scheme Programming 14 December 6, 2012 14:39
