Automating multiple simulations with different boundary conditions |
Tom Rich
Rep Power: 7 ![]() |
I am trying to set my computer to run several simulations at different mach numbers and somehow save the lift generated by a grid for each case, it seems that you'd do this through the text interface but i dont know how to go about saving it or creating a loop. Any guidance or links to learning material to do with this would be appreciated
Alexander
Rep Power: 34 ![]() ![]() |
you may use journal to do this
make a loop to load your cases (or 1 case several times, up to you), using TUI commands: set boundary conditions, run simulation, save data, repeat for instance, this code will load case1 case2 and case3 one by one Code:
(do ((i 1 (+ i 1)))((> i 3)) (ti-menu-load-string (format #f "file read-case \"case~a.cas\" OK \n" i)) ) Code:
(do ((i 1 (+ i 1)))((> i 3)) (ti-menu-load-string (format #f "file read-case \"my_case.cas\" OK \n" )) ) best regards |
Tom Rich
Thankyou i'll give this a go
automated, multiple simulations |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Problem with SIMPLEC-like finite volume channel flow boundary conditions | ghobold | Main CFD Forum | 3 | June 15, 2015 11:14 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 11:19 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 17:30 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
