Steady State solution and Transient solution
Old   March 9, 2019, 07:28
Default Steady State solution and Transient solution
Arijit Saha
ari003 is on a distinguished road
What is the difference between steady state and transient solution?
Based on the application how can I figure out that which solution to use?
It will be really helpful if someone helps.
ari003 is offline   Reply With Quote
Old   March 9, 2019, 13:14
Lucky
steady state means its time independent and transient means its allowed to change in time.
For most cases steady state works, because you are doing RANS which solves for the temporal-averaged velocity.
But if you have a time-dependent velocity inlet for example, then the solution would obviously also me time-dependent and you would need to do a transient simulation.
Sometimes there are inherent unsteady effects in the flow, like vortex shedding, which sometimes necessitates a transient simulation.
2way FSi, Initialize with steady solution, Fluent, Transient Sturcural, System Coupli mmkkeshavarzi FLUENT 1 June 28, 2024 08:03
The difference between steady state and transient JuPa CFX 36 December 9, 2019 23:50
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 06:37
Steady state solution ----> transient nskelly OpenFOAM Running, Solving & CFD 4 March 12, 2018 12:49
Steady state solution as an initial condition for a transient problem adnanakhtar FLUENT 7 November 25, 2016 06:16
