Hydroforming simulation problem
Old   March 6, 2019, 04:13
Question Hydroforming simulation problem
Shahab Khakpour
Shahab Khakpour is on a distinguished road
Hello everyone,
I am going to simulate hydroforming process of a close-end pipe. I need to apply velocity as the inlet and all other surfaces should be considered as the wall. I did it through two approaches: 1- one-way FSI: I solved the fluid model via fluent and linked the solution to the transient structural. I considered the fluid pressure on the wall as the external force for structural analysis and 2- I tested two ways FSI via system-coupling and in both cases, I faced with the same problem:
At the beginning, only the positive pressure exists at the close-end region and all of the tother regions have negative pressure. By keep going, the positive pressure moves toward the inlet, but after 5 mins of simulation, still, one third of the pipe has negative pressure. The negative pressure causes shrinkage of the pipe, while the aim of the hydroforming is inflation of the subject. I think it could be due to that there is not any outlet. I use k-e turbulent model and I have tested multiphase flow, but it did not work.
I would greatly appreciate it if you could help me that.
Shahab Khakpour is offline   Reply With Quote
close-end pipe., fluent, negative pressure
Problem with restart in FSI unsteady simulation david_mocholi SU2 1 June 24, 2023 07:06
Convergence Problem - Transient Simulation gemxx Main CFD Forum 0 July 15, 2018 10:36
Problem with multi stage compressor simulation. Geant18 CFX 0 June 22, 2018 06:03
Problem with wall surface reaction simulation in Fluent suren1992 CFD Freelancers 1 June 7, 2018 05:14
Large-scale simulation problem Purushothama Main CFD Forum 0 November 7, 2010 21:12
