Units in 2D analysis
Old   March 5, 2019, 09:27
Default Units in 2D analysis
crinoid
crinoid is on a distinguished road
When using Fluent with a 2D mesh, the results which are shown are per unit of length?
I am studying the heat transfer between some tubes in cross-flow with cold air and Fluent computes the pressure drop (pa) and heat exchange (w). Do I have to multiply those numbers by the length of my tubes?
Thanks in advance
crinoid is offline   Reply With Quote
Old   March 5, 2019, 23:57
Behrooz Jamshidi
CFD-fellow is on a distinguished road
The answer of your question is completely dependent on the result variable definition and derivation. For example the pressure drop in cross flow is not dependent on the length of tubes while heat exchange is dependent and the value is calculated per unit of length and must be multiplied by the length of tubes.
CFD-fellow is offline   Reply With Quote
Old   March 6, 2019, 05:21
crinoid
Sounds logic, thank you for your answer!!
Old   March 6, 2019, 09:57
Moritz Kuhn
MKuhn is on a distinguished road
Some values like volume, flow rate and volume integrals are calculated with the Reference Depth in a 2D-analysis, which you can change under "Setup" and "Reference Values"
MKuhn is offline   Reply With Quote
Old   March 7, 2019, 08:14
crinoid
Ok, thanks!!
Would it be possible that the heat flux was express per units of area (considering pi * diameter * 1 m)?
Old   March 7, 2019, 08:43
Moritz Kuhn
By default settings yes.
heat transfer, units
Urgent - Perform an DISCRETE adjoint analysis in parallel_computation JPBLourenco SU2 1 April 23, 2018 11:38
Explicit dynamics results for initial condition to another explicit dynamics analysis KOI Structural Mechanics 0 March 2, 2018 05:16
Flutter analysis of compressor blade sridharabc228 CFX 1 April 13, 2017 20:10
ANSYS WORKBENCH Transfer result of one analysis to a new analysis as preload ingjuanm90 ANSYS 0 July 26, 2016 15:04
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
