Post processing in ansys fluent
Old   March 1, 2019, 15:10
Default Post processing in ansys fluent
Ankur
@nkur is on a distinguished road
Sir, I am new to ansys
Instead of modeling complete shell and circular finned tube heat exchanger consisting of number of tube rows in both horizontal and vertical directions, i have modeled only a small 3D portion of it considering its symmetry and carried out the simulations. I have considered air as fluid on the shell side and given constant temperature for the tubes.
Now should i calculate the different dimensionless nos such as Reynolds Nusselt etc. and hydraulic diameter ( focussing on the shell side) for that small 3D portion only or should i consider the whole heat exchanger for calculating those things
@nkur is offline   Reply With Quote
Fluent in Ansys Workbench : Change Working Directory sral FLUENT 4 March 29, 2019 11:29
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
How to combine ANSYS Fluent and Structural analysis? diwakar ANSYS 2 June 18, 2015 13:07
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
Ansys Post Processing Brian_P Main CFD Forum 0 March 4, 2010 17:05
