February 27, 2019, 19:20 |
airfoil in ground effect
kia abdollahi makuyi
Rep Power: 8 |
Hi everyone!
I’m trying to simulate flow field around an airfoil in ground effect using Transition k-kl-omega turbulence model in a ground clearance varying from h/c=1 to h/c=0.05 (h/c = ground clearance/chord). In terms of Cd I get quit good results compared to experimental data, but in h/c=0.05 and 0 AoA the Cd is much bigger than the real value as shown in the attached picture. The attached mesh emage is for 10 AoA. Is there any explanation for the jumb in Cd?! How can I fix it? By the way, flow properties are as below: Re = 3e+5 V = 4.4m/s Regards |
Mesh geometry over airfoil with Gambit | laith | FLUENT | 5 | March 9, 2018 02:56 |
Problems finishing implementation of 2D Linear-Strength Vortex Method (Airfoil) | al3x | Main CFD Forum | 4 | October 5, 2017 11:56 |
Symulate hysteresis stall effect on an Airfoil | sirnick | FLUENT | 6 | March 6, 2012 07:55 |
Ground Effect | willis | Main CFD Forum | 6 | January 26, 2012 21:32 |
Wing on ground effect | John Tong | FLUENT | 0 | September 5, 2006 00:31 |
