Dasac failure at temperature error during combustion simulation
Old   February 25, 2019, 14:20
Default Dasac failure at temperature error during combustion simulation
Ghadeer
Holagee is on a distinguished road
Dear all,
I am trying to simulate a combustion of propane and oxygen using detailed chemkin mechanism (GRI Mech 3.0) and I modified the mechanism files to include 3 additional charged species (I got the thermo/transport info from NASA Glenn Coefficients document). I used stiff chemistry solver with pressure-based and when I ran the simulation after ignition, each iteration step takes so much time and I see the "Dasac faliure at temperature: ( ) K: Continuing..." statement frequently in the print console. The process could not continue with a last error that says "Cortex received a fatal signal (Segmentation Violation)".
I think the problem is clearly from the modified files, because I ran the same simulation again without modifying the original GRI Mech 3.0 files and it ran fine. But how do I fix this? There are many journals/papers that managed to include charged species in their simulations by modifying the chemkin files (same approach) but is there something that I missed? Maybe the ANSYS chemkin library does not support charged species or something?
Holagee is offline   Reply With Quote
Oxy-Fuel combustion dasac failure Pat84 FLUENT 3 November 15, 2018 04:42
Help with a biomass combustion simulation pelletburner Main CFD Forum 0 June 13, 2017 16:26
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 18:00
coal combustion temperature failure a_cucen FLUENT 4 April 24, 2014 05:08
why is solid temperature same as fluid temperature on flow simulation ? qihongming FloEFD, FloWorks & FloTHERM 0 May 26, 2009 09:57
