Very noisy results in the flow around the tube array
Old   February 22, 2019, 07:39
Default Very noisy results in the flow around the tube array
Shay
Shay_ is on a distinguished road
I study a two-dimensional simulation field with a SAS model in three different grids(the same grid with different domain size) and the results obtained in the fluent are very noisy in space. You can see an example of static pressure on one of the tubes and noise. I also get this noise at mean velocity magnitude along vertical lines in the flow domain.
This noise is also obtained in both average results in time and in momentary results.
I can not undestand the reason for this noisy results, it seems to me not physical.
I would be happy to know if anyone encountered such a thing and / or know how to solve it.
Thank you,
Shay
Shay_ is offline   Reply With Quote
SU2 Transonic Flow simulations bad results S.Kontogiannis SU2 12 June 20, 2019 08:46
Flow and heat transfer across a periodic array of cylinders. Ashley_114 FLUENT 0 April 4, 2017 16:54
Get Maxwell ansoft results in ansys workbench and find the flow velocity in Fluent, i rrahman FLUENT 0 April 16, 2016 22:11
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 06:44
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
