Particle tracking file per time step in an Unsteady Particle Tracking
Old   February 19, 2019, 04:02
Default Particle tracking file per time step in an Unsteady Particle Tracking
Manu4CFD is on a distinguished road
While running an unsteady particle tracking simulation in Ansys Fluent 13.0 with DPM model, how can we write the particle tracking summary for a particle injection (in-order to know the particle fate) in to a file for every time step or after every prescribed number of time steps? For instance,say, my total simulation time is for 100s and I need to write the particle tracking summary for every one second. How can we do it? Kindly let me know your valuable comments.
Manu4CFD is offline   Reply With Quote
Old   December 29, 2022, 08:15
Kailash Choudhary
Kailash Choudhary is on a distinguished road
My name is Kailash Choudhary.
I have the answer to your question.
How I did is like, in 'Graphics', go to 'Particle Tracks' and select 'Current Positions' and report to 'File' type. Then in 'Reporting Variables', select the variables you want to see. Then 'Save/Display' with, let's say name 'Output.dpmrpt'.
The tricky part comes now. So basically, this will save the data of this step only, and to update data at other flow timestep, make one animation for this 'Particle Track', this way, the data in this file will get updated whenever the Animation file is saved.
Now the data in this file will update but name of the file will be same and all the data will be over-written in this one file only. To solve this problem, I wrote a UDF code to re-name this file, so that fluent will create a new file in the absence of file with ''Output.dpmrpt'.
The udf code I wrote is --
/*This will rename the file "OUTPUT.dpmrpt" which will be generated at each animation save this file contains data of particles in the domain*/
DEFINE_EXECUTE_AT_END(execute_at_end)
char filename[50];
char old_name[50];
snprintf(filename,50,"Time_%06.f.dat",ceil(CURRENT _TIME));
snprintf(old_name,50,"OUTPUT.dpmrpt");
rename(old_name, filename);
Attach this code at 'Function Hooks' -- 'Execute at End'.
In this, I faced a problem that sometimes particle track gets un-selected. So every time before starting the Run Calculation/Compute, to the particle track steps again.
Thank you
Let me know if you still have any problems with this.
Sorry for replying after 4 years (HaHa).
Last edited by Kailash Choudhary; January 5, 2023 at 07:08. Reason: Added more explanation.
Kailash Choudhary is offline   Reply With Quote
[swak4Foam] Installation Problem with OF 6 version Aurel OpenFOAM Community Contributions 14 November 18, 2020 17:18
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 01:01
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 11:59
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 04:23
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
