February 14, 2019, 06:01 |
Cyclic symmetry / Axisymmetrical flow
PRAVEEN KUMAR
Rep Power: 9 |
Good day everyone,
I am new to Fluent, trying to use cyclic periodic boundar condition for a swirl flow inside a cylinder. I have read the Fluent tutorial and modelled only 30deg section of the whole cylinder (to reduce the mesh to 1/12 of its size), created named section, set symmetric periodic BC and set match control in periodic faces (low and high). Then, I made those faces periodic using "mesh-modify_zones-make_periodic" command. Those faces were made periodic!! But, when i initialise and run the simulatiom, i found that shadow face is open at the coordinate axis. I try to solve it by alternating the periodic and shadow faces, now it appears on other side. I don't know how to solve this. Can someone please help me with this!! Note: The attached picture is no my exact model, but i am showing it for better understanding. Regards Praveen Kumar mesh.jpg solution_pic1.jpg solution_pic2.jpg solution_pic3.jpg Last edited by praveencyr; February 21, 2019 at 08:17. |
axisymmetric swirl, edges, mesh 3d, periodic bc, swirl flow |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 19:00 |
Problems building Paraview 3.12 on Gentoo Linux | pajot | OpenFOAM Installation | 11 | April 11, 2013 09:09 |
[swak4Foam] installing funkySetFields | igo | OpenFOAM Community Contributions | 1 | November 20, 2012 21:16 |
Where's the singularity/mesh flaw? | audrich | FLUENT | 3 | August 4, 2009 02:07 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
