February 13, 2019, 15:22 |
DPM Sample Report Error
Eanna Kennedy
Rep Power: 7 |
This is related to an optimization project I have posted about on here before. For the project I need to calculate the standard deviation of particles about the centre of a channel on a plane near the outlet. I then need to return this an output parameter to be used in direct optimization. The only way that I have been able to access the particle data i need is by using a DEFINE_DPM_OUTPUT. This means that i have to run a dpm sample report for every simulation so that the output parameter can be calculated. I also haven't been able to find a way to get the sample report to run at the end of a calculation. So I decided to set up a command in calculation activities which tells fluent to write a sample report for every iteration but this causes fluent to crash on the third iteration every time. Fluent also crashes if I try to create the report from the GUI or TUI, again always on the third time. I'm guessing that this is a file overwriting problem but I really don't know and any help would be appreciated. The attached image shows the error message from the console as it crashes. Finally I don't really like this method of calculating the output parameter as it wastes a lot of processing time, is there any easier way to get the data i need? |
[OpenFOAM] an error in Calculator's equation | immortality | ParaView | 12 | June 29, 2021 01:10 |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 12:39 |
Undeclared Identifier Errof UDF | SteveGoat | Fluent UDF and Scheme Programming | 7 | October 15, 2014 08:11 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 08:24 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 07:42 |
