February 13, 2019, 04:04 |
Draining tank analysis
Lorenzo
Rep Power: 7 |
Hi everyone,
I am a new user, eager to learn as much as possible from all of you :-) I am facing a problem which is causing me some troubles. My goal is to estimate the flow rate through a vertical pipe connected to a tank, simulating the emptying of the latter. So, basically it's a gravity problem with 0 pressure on the free surface of the oil and on the discharge section of the nozzle. I employed a viscous-laminar model with energy activated. Gravity is of course enabled. Even though I should use a transient solution, it requires way too long for the solution to converge (for all the oil in the tank to drain). Hence I studied the problem with a steady approach. I specified all the oil properties in the materials section, writing them as functions of temperature. What I'd like to know is: - how do I deal with the Bussinesque's parameters? If I do not check the "operating density" box in the cell zone condition, the solution converges at the very first iteration, providing me zero flow rate. If I check that box, which density should I give as input? - Should I specifically express the zero-pressure location in the "cell zone conditions" menu even though I've already specified the pressure inlet/outlet in the boundary conditions? Ciao, Lorenzo Edit: for the sake of completeness, I think it can be useful to say that I got a solution but it does not match the experimental data: the flow rate I obtain is half of the experimental one. Last edited by lorenzoalari; February 13, 2019 at 05:14. |
How to implement a sensitivity analysis for certain items | Mason liu | CFX | 10 | August 17, 2017 09:46 |
Pressure Temperature Evolution in Tank Venting by VOF model-FLUENT | avi@lpsc | Main CFD Forum | 0 | August 4, 2014 07:25 |
Flow analysis in an enclosed tank | lee87 | Main CFD Forum | 0 | March 30, 2014 03:37 |
Surge tank | sachin | Main CFD Forum | 0 | November 18, 2005 08:42 |
CFD analysis of Fluid Flow over a Weir in a Tank. | ronan moore | Main CFD Forum | 2 | February 4, 2005 08:15 |
