Fluent 19.0 Lift and Drag Coefficient Monitors
Old   February 6, 2019, 18:21
Cool Fluent 19.0 Lift and Drag Coefficient Monitors
TeriSerugi is on a distinguished road
I am trying to simulate the Von Karman effect using ANSY CFD Fluent version 19.0 and am having some issues with the lift and drag coefficient monitors. When I monitor the lift and drag coefficients I see that they are many orders of magnitude lower than I expected. I am attempting to set the range of the axis for each monitor individually and am having some issues. I want to set the range for the drag coefficient from 1.2 to 2 and the range for the lift coefficient from -.25 to .25 however I can't figure out how to do this. When I go to the residuals menu and click on the axis button, I am not asked which monitor I wish to apply the settings to. It seems as if this is adjusting the global settings for all monitors in the simulation. This used to be easier in earlier versions and I am not sure what I am doing wrong. Any help would be much appreciated. Please let me know if I need to clarify my intentions. Thank you so much.
TeriSerugi is offline   Reply With Quote
Calculation of lift and drag coefficients on airfoil CoolHersheys OpenFOAM Post-Processing 5 September 27, 2021 07:04
wrong SU2 calculation for lift and drag coefficient for NAC4421 mechy SU2 7 January 9, 2017 06:18
drag and lift coefficient fluent bia FLUENT 10 October 22, 2014 04:40
Drag and Lift coefficient in Fluent pejmanpark FLUENT 0 July 13, 2011 13:11
Fluent Good Lift coefficient BAD drag coefficient Rif Main CFD Forum 4 March 9, 2010 11:52
