Varying Mach Number with Design Points
Old   February 4, 2019, 15:05
Default Varying Mach Number with Design Points
Alex
QuantumAJ is on a distinguished road
I have a aerofoil modeled and meshed and I would like to vary the Mach number from 0.6 to 1.2. I have set up the boundary condtions such that the inlet velocity is a parameter and the farfield mach number is also a parameter. I would like to compute this range in small 0.5 increments and using the desing points would make easy work of this. My question is, if i change the mach number from design point to design point, do I loose my Initialization compute from and referance value.
For example, In DP 1, I compute from inlet with mach=0.6, in DP 2, is the inlet Initialization still m=0.6 or is it m=0.65 as defined in the table?
Thanks
Al
QuantumAJ is offline   Reply With Quote
Old   February 4, 2019, 17:12
Lucky
If you use "compute from" then it will use whatever properties are assigned to the boundary. So it will update to use the M=0.65.
But if you're going to vary the solution in small increments, it might be a better idea to just change the BC and not re-initialize. Just use the solution at M=0.6, change the mach number, and then keep iterating. The converged solution at M=0.6 might be a better initial condition than a blind initialization.
Old   February 5, 2019, 05:10
Alex
Thank you for the reply LuckyTran.
Im looking to plot the Cd and Cl vs Mach number on a graph, would this be the best method of obatinign the data? I like the design points as I can export it to .cvs file.
ansys fluent 18.0
[snappyHexMesh] snappyHexMesh sticking point natty_king OpenFOAM Meshing & Mesh Conversion 11 February 20, 2024 10:12
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' BrendaEM OpenFOAM Meshing & Mesh Conversion 12 April 3, 2022 19:32
decomposePar -allRegions stru OpenFOAM Pre-Processing 2 August 25, 2015 04:58
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 19:45
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
