Moment Center and Moment Axis as a function on flow-time |
Federico
Rep Power: 8 ![]() |
Dear all,
I am currently working on a sliding mesh set-up involving the simulation of the flow passing through a tidal turbine. One thing I am struggling with is how to monitor the moment of a force in such a problem: At each time step (if I refer to a blade) I have that Moment center coordinates and moment axis components are changing. I tackled this aspect by typing on execute command text line the following: (define t (rpgetvar 'flow-time)) (define omega 7.644542) solve/monitors/force/set-moment-monitor cm-x y 28 33 , y y /Path/to/cx1.txt n n (* 0.036 (sin (* omega t))) (* 0.036 (cos (* omega t))) 0 (- 0 cos (* omega t)) (sin (* omega t)) 0 The following warning and errors appears although a cx1.txt file is outputted: (define t (rpgetvar 'flow-time)) t (define omega 7.644542) omega Error: + (add): invalid argument [1]: wrong type [not a number] Error Object: #[primitive-procedure cos] solve/monitors/force/set-moment-monitor cm-x y 28 33 , y y /Path/to/cx1.txt n n (* 0.036 (sin (* omega t))) (* 0.036 (cos (* omega t))) 0 (- 0 cos (* omega t))Invalid real. (sin (* omega t)) 0 z-component of moment axis [0] Anybody knows what this Errors mean? I would like to stress the fact that a file ( cx1.txt) was written! Do you think the aforementioned mathematical expression was calculated? Hope you can help me with this!! Thank you in advance Best regards, eeLio |
#2 | |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
I think the issue is this comma , appearing here but I can't really tell because I don't know your entire case setup. Just go into Fluent and manually type in solve/monitors/force/set-moment-monitor and then follow the prompts. |
execute command, force monitor, sliding mesh, turbine |
Working with Python: Query of through-plane flow of multiple clips in one plot | PedroInvierno | EnSight | 8 | April 10, 2017 09:23 |
Valve Design Flow Forces, Report moment | Mans1234 | FLUENT | 1 | August 10, 2015 17:28 |
Failed to simulate wind turbine based on wingmotion tutorial with pimpleDyMFoam | gohome | OpenFOAM Running, Solving & CFD | 0 | July 8, 2014 04:12 |
Center of pressure (confirmation/question) | scipy | FLUENT | 2 | March 5, 2012 06:54 |
Writing Moment coefficient for different walls at different rotational axis | harishameed33 | Main CFD Forum | 0 | April 27, 2010 12:17 |
