Enthalpy vs temperature curve
Old   January 28, 2019, 11:01
Default Enthalpy vs temperature curve
Karthik
kr660170 is on a distinguished road
Dear All,
I am working on the Simulation of Paraffin wax (Phase Change material). Can someone explain me how to create enthalpy vs temperature curve in Ansys Fluent? I am looking forward for your reply. Thanks in advance.
Kind Regards,
Karthikkumar
kr660170 is offline   Reply With Quote
Old   January 28, 2019, 22:29
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
https://www.grc.nasa.gov/www/k-12/ai.../enthalpy.html
H2 - H1 = Cp(T2- T1)
best regards
AlexanderZ is offline   Reply With Quote
Old   June 2, 2020, 07:42
Daniel Marques
DanielMarques is on a distinguished road
I am not sure but maybe you will need to see something about UDFs.
Have you solved it?
Could you also help me with someting?
I am simulating the use of a phase change material with low temperature melting point. The idea is to place a slab of pcm around a pipe of an heat exchanger so i did a 2D model with a circle inside a rectangular shape of PCM.
For the PCM i used piecewise-linear properties at density, thermal conductivity and specific heat. For the liquidus and solidus temperature i inserted a 0.5 tolerance from the real point. For example 251.5 and 252.5 Kelvin for a melting point of -21 degrees.
On boundary conditions I used adiabatic walls at top and bottom of the rectangle. At the outside wall I placed temperature fixed at 298K since the material is polyurethane and I added a thickness of 0.09m. At the inside wall of the rectangle I used convection BC with 255 Kelvin, an h value of 5 and a very small thickness of aluminium. The pipe of the heat exchanger BC was coupled.
When simulating for a time step of 1s I have sometimes the problem of floating point exception. And the simulation is already taking a lot of time.
I also tried adaptative time step using 0.01 of tolerance with fmin=0.9 and fmax=1.5 but the simulation is taking too long...always using time-steps around 10-3. I will need months for a single simulation without beeing certain if the floating pointe exception error will happen again or not.
I tried to use a refined enough mesh and the levels of skewness on the metrics are good i guess since the max value is 0.6 and the average is very low.
Many times this model is reaching a situation of floating point exception. Could you help?
DanielMarques is offline   Reply With Quote
Enthalpy to temperature adhiraj OpenFOAM Programming & Development 16 May 31, 2017 03:26
Enthalpies: Am I confused or is OpenFOAM? (rel. standard vs. enthalpy of formation) KarenRei OpenFOAM Running, Solving & CFD 8 November 10, 2016 19:18
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 18:30
Energy Equation solve the Temperature or Enthalpy? mikahang FLUENT 0 September 26, 2013 02:48
Solve Enthalpy or Temperature? sheng Main CFD Forum 5 January 22, 1999 10:40
