Modeling a vertical axis wind turbine / Negative momentum coefficient
Old   January 24, 2019, 18:19
Default Modeling a vertical axis wind turbine / Negative momentum coefficient
Felipe Murcia
Felipe06 is on a distinguished road
Hello for everyone in this forum:
Recently, I was modeling a VAWT (Vertical axis wind turbine) Daerrius H type in 2D and I had a problem with the converge of the solution. The problem was that never converging the solution. I used the K epsilon model; the mesh was triangular elements. But, the results of momentum coefficient are negative or values highest than one
and if I use the equation for calculate the power coefficient
Cp = Cm * TSR
I will get values of power coefficient higher, and the power coefficient should not exceed the Betz limit established in 0,59
I did this simulation in steady state using a MRF (Multiple Reference Frames). The main idea is to use the convergent MRF results and simulate a transitory stage using the sliding mesh technique.
I attached the domain used and the graph with the results of the momentum coefficient. I did 12000 iterations, because in the forum many people said that, they did more iterations to get the result.
If someone can help me, I would appreciate it.
Felipe06 is offline   Reply With Quote
fluent, momentum coefficient, mrf, vawt
Vertical Axis Wind Turbine skypertross FLUENT 0 March 16, 2016 05:00
Vertical Axis Wind Turbine f.gig Fidelity CFD 4 May 30, 2014 10:57
Airflow over Vertical Axis Wind TUrbine sthoms78 ANSYS 8 April 10, 2013 03:31
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
3 bladed Vertical Axis Wind Turbine transient CFD ArslanOZCAN FLUENT 1 February 5, 2011 09:34
