January 19, 2019, 02:04 |
An error in building mesh
Bing Zhang
there are details :
Building... mesh materials, interface, domains, mixture zones, wallmoving symmetry wall outlet int wing solid interior-solid wall-solid Error: get-thread: invalid thread id (integer) or name (symbol) Error Object: # |
January 19, 2019, 02:09 |
Bing Zhang
dose anyone know these?
January 20, 2019, 11:28 |
Malthe Haahr Hvelplund
Rep Power: 9 |
It is very hard to tell from your description.
Often the problem is how you have drawed your geometry. You can maybe try to simplify your geometry and mesh and see if that works. The auto generation tool/Check mesh/repair works very well. You can take a look at the tutorial file of ICEM and follow the user guide. Ofcause this will only work if you are working in ICEM. |
fluent 14 to fluent 15. |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[snappyHexMesh] SHM problem : KVLCC2 with appendage mesh | sc.park | OpenFOAM Meshing & Mesh Conversion | 1 | March 13, 2016 13:28 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
