How do I solve the following heat transfer problem? |
January 18, 2019, 12:37 |
Saurabh Das
Rep Power: 8 |
I have the following problem to solve: a steel block is subjected to laser irradiation for a small amount of time. It’s then switched off and liquid nitrogen is flushed onto the metal. I wish to observe the thermal effects of such a process on the steel block.
How should I proceed? How do I make a '2D enclosure'? Any input would be greatly appreciated. |
January 18, 2019, 14:33 |
Lucky
Rep Power: 66 |
Well first you need to mesh the domain (steel block + nitrogen domain). What meshing tools have you decided to use? Have you done any tutorials.
January 19, 2019, 20:58 |
Saurabh Das
Rep Power: 8 |
I am yet to understand how to define and differentiate the 2 different domains. All the tutorials I have checked do not take into account any thermophysical processes in the steel block..
January 19, 2019, 21:32 |
Lucky
Rep Power: 66 |
You need separate cell zones. Once you've you've got a mesh with two cell zones, you just specify the steel block as a solid cell zone and you're pretty much done. It is a piece of cake. So your biggest hurdle is the meshing part.
January 24, 2019, 10:40 |
Saurabh Das
Rep Power: 8 |
Yeah, I made the geometry part with relative ease, but I am stuck at meshing.
I can't seem to control the mesh of the inner zone no matter what mesh control methods I use. I used edge sizing on all the edges, but the mesh of the inner zone won't change... Help, please?? |
January 24, 2019, 10:43 |
Saurabh Das
Rep Power: 8 |
EDIT: <removed double post>
February 4, 2019, 04:15 |
SS
Rep Power: 8 |
I suppose you're using Ansys meshing. Can you share a pic of the geometry? Sometimes Ansys meshing is a bad tool for meshing CFD domains.
February 5, 2019, 20:22 |
Rep Power: 10 |
Just out of curiosity, are you sure that when you are using edge sizing you are actually selecting the correct body? For instance, if you hide the exterior (gray) body and then apply edge sizing to the inner (blue) body, does it work?
April 27, 2020, 13:54 |
#9 | |
Mayur Bhandari
Dear Sorabh, Have you solved your problem? Can you suggest me proper tutorial for this ? Thanks in advance |
2d enclosure, flow over a cuboid |
Inverse and Transient Heat Transfer Problem on commercial software: is it possible? | rogbrito | Main CFD Forum | 1 | February 19, 2019 03:11 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 06:15 |
CFX does not solve heat transfer at fluid-solid interfaces | Ivan Corgozinho | CFX | 2 | April 7, 2015 01:08 |
Heat Transfer mechanisms | tafaugl | CFX | 1 | November 7, 2012 19:46 |
regarding B.C. of Heat transfer problem | Manoj Padmakarrao Raut | Siemens | 0 | March 17, 2005 01:01 |
