January 17, 2019, 18:58 |
Issues with rotating cell zone.
i'm currently trying to model the airflow over a rotating ring and experiencing an issue as pictured. (The airflow is right-to-left, the boundary of the rotational domain can be seen clearly.) Having defined the rotating cell zone with 'Mesh motion' condition and plotting a velocity contour over the model, it appears that the fluid (air) within the zone is not behaving as i would expect. I am a fairly new user and i appreciate there are nuances to the program, but this does not look realistic. Some input from more experienced users would be much appreciated. Some things which may be useful: 1. The model is k-epsilon, realizable with scalable wall function 2. Transient simulation with time step of 0.02s 3. Ring rotational velocity of 3000rpm and a uniform air velocity over the ring of 15m/s 4.The wall of the rotational domain boundary is set as "moving wall", matching the speed of the ring, however the results are similar even with a stationary wall. All input is appreciated. |
FvMatrix coefficients | shrina | OpenFOAM Running, Solving & CFD | 10 | October 3, 2013 15:38 |
Cell Zone Size Question | Maralady | FLUENT | 0 | July 2, 2013 02:47 |
Question about common cell zone interaction | Maralady | FLUENT | 0 | June 18, 2013 00:31 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 22:58 |
Sliding mesh error | Karl Kevala | FLUENT | 4 | February 21, 2001 16:52 |
