Saving surface monitor file
Old   January 17, 2019, 15:04
Default Saving surface monitor file
Mehdi Bouayad
Mehdi Bouayad is on a distinguished road
I have a probleme with saving surface monitor output file, the space for specifying the output file name is blocked even though I checked on "write"
I don't know where the probleme is
please help, regards
Mehdi Bouayad is offline   Reply With Quote
Old   January 18, 2019, 00:42
Lucky
It's blocked because you are using workbench. It would be unblocked if you opened up Fluent directly. I'm not sure how to setup the monitors in workbench. Maybe someone else can help you with that if that's how you want to set it up.
Old   January 21, 2019, 09:37
Mehdi Bouayad
Oh It worked when i open Fluent without workbench, thank you very much for your help
How To Create Fowcs William Hawkings Surface in Fluent? marinkobezu FLUENT 7 October 25, 2018 11:51
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 12:05
[snappyHexMesh] Add additional boundary layers to complex stl surface tobijingles OpenFOAM Meshing & Mesh Conversion 1 October 26, 2011 11:45
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin Kaushik FLUENT 1 May 8, 2000 07:47
