How to get velocity at each node of meshing at each time-step in Ansys Fluent? |
January 14, 2019, 05:43 |
mkhan
Rep Power: 8 |
Hello All!
I am looking to get data for each time step at all the 10000 nodes of the meshing in Ansys Fluent. I need to monitor x-velocity, y-velocity, and vorticity around 2D circular cylinder. I do not know how to get that. Can somebody please help me with that... I also write a journal file to create all these 10000 points in order to use surface monitors, but fluent showed some error due to a large number of nodes. Thanks! |
January 14, 2019, 07:13 |
Rep Power: 9 |
I suggest you to save your solution in ensight gold format, then you can use paraview to retrieve all the information you need.
January 14, 2019, 07:37 |
#3 | |
mkhan
Rep Power: 8 |
Can you please explain to me how to do that and thanks... |
January 14, 2019, 10:47 |
Lucky
Rep Power: 66 |
Go to calculation activities and setup an automatic export during transient simulation.
Do not select any surfaces! Choose nodes if you want nodes, leave empty if you want cell centers. Choose your export format, ascii if you don't have a preference. If you do not choose any surfaces, it will write at every single cell in the domain. If you choose any surfaces, it will write only on the surface and not the domain. Choose all the variables you want (velocity, etc.). You do not need to select x,y,z coordinates. The x,y,z locations will always get written. |
January 15, 2019, 02:04 |
#5 | |
mkhan
Rep Power: 8 |
p_rgh initial residual no change with different settings | manuc | OpenFOAM Running, Solving & CFD | 3 | June 26, 2018 16:53 |
pressure in incompressible solvers e.g. simpleFoam | chrizzl | OpenFOAM Running, Solving & CFD | 13 | March 28, 2017 06:49 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 14:41 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 01:01 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 05:03 |
