2D Inviscid Flow Problem
Old   January 11, 2019, 18:06
Default 2D Inviscid Flow Problem
S.M.A Taleghani
Sma4t is on a distinguished road
I'm trying to solve the following problem in fluent:
The flow is assumed to be 2D, inviscid and incompressible. The flow domain has an inlet at the bottom and an outlet on the right face.
Boundary conditions are given in terms of Psi (stream function) where:
The governing equation is:
It is required to plot the streamlines (Psi = constant lines) of the flow.
The first Idea that came into my mind was to assume Psi=Temperature and the governing equation will become the Laplace equation. Therefore the Psi-constant B.Cs will turn into Temperature constant and the inlet and outlet velocities can be simulated as the heat flux in the vertical and horizontal direction.
I wanted to know if it's possible to simulate the actual flow in Fluent regardless of the trick above. I don't have any ideas how to set Psi=constant B.Cs in Fluent.
Any help is appreciated.
Kind Regards,
Mohammad
P.S: This is a project for "An Introduction to CFD" undergraduate course which required comparing the FDM and FVM method for this problem. The FVM was said to be solved using Fluent.
Sma4t is offline   Reply With Quote
Old   January 11, 2019, 18:17
Lucky
Fluent has an inviscid flow model, but it solves the Euler equation and not the potential equation.
You would need to use the trick to solve it in Fluent using Psi = temperature. You just set the wall temperatures to specify Psi.
Old   January 11, 2019, 18:23
S.M.A Taleghani
LuckyTran,
Yes, I know. But how is it possible to give stream function BC's?
The answer the PDE of the problem looks like this (Psi is defined as Temperature):
But using Fluent's inviscid model with only wall BC's and an inlet and outlet velocities gives this:
Old   January 14, 2019, 12:47
Lucky
There isn't really an equivalent of specifying the value of the stream function into the Euler equations.
Psi = constant on any boundary just means that there is no velocity normal to the wall and any velocity is in the wall parallel direction. The wall boundary condition does this. And any value of psi satisfies this condition.
I'm not sure why you have values of 0 and 100 for Psi in this particular case, but in airfoils for example, you need to specify psi to satisfy the kutta condition.
fluent, inviscid, inviscid flow, stream function
Estimation of viscous Lift & Drag coefficients from inviscid flow in optimization. freebird Main CFD Forum 1 June 3, 2018 04:40
How would I write a 2d steady, inviscid, and incompressible flow simulation? 7he404guy Main CFD Forum 5 January 13, 2017 17:04
Having Problem solving 2D supersonic flow around a plug nozzle chrislloyd FLUENT 7 July 22, 2015 14:09
Newbie to compressible, viscous flow. Advice on approach to problem? bzz77 Main CFD Forum 4 December 4, 2012 08:59
Periodic flow boundary condition problem sudha FLUENT 3 April 28, 2004 09:40
