Determination of Air Change Rate in a room through CFD simulation in Ansys Fluent
Old   January 10, 2019, 02:13
Default Determination of Air Change Rate in a room through CFD simulation in Ansys Fluent
Manu4CFD is on a distinguished road
Consider a room as depicted in the picture. The room has two supply diffusers at the ceiling and six floor level exhaust grilles (three exhausts are shown in the picture and other three exhausts are located on the opposite side). The room under study needs an air change rate of 3ACH. Based on the air change rate required, the mass flow rate through each supply diffuser is determined to be 0.62kg/s. The door (considered open) as well as the six floor level exhausts are given a pressure outlet condition of 0Pa. All the walls are adiabatic. The CFD simulations are carried out in Ansys Fluent under steady state condition. If in case, the pressure conditions at each floor level exhausts are altered to -1Pa (negative pressure), would it be right to say that the air change rate provided to the room is still 3ACH? Kindly provide your valuable comments.
Manu4CFD is offline   Reply With Quote
CFD simulation of gas cicrcuit breaker in fluent with dynamic meshing. Mahesh7238 FLUENT 1 April 5, 2021 01:21
Fluent in Ansys Workbench : Change Working Directory sral FLUENT 4 March 29, 2019 11:29
How to calculate torque of the shaft for turbines in CFD fluent simulation ? jeevmech FLUENT 0 September 25, 2016 00:30
1way FSI simulation using ansys structural and Fluent mmkkeshavarzi FLUENT 0 August 5, 2015 11:49
Where do we go from here? CFD in 2001 John C. Chien Main CFD Forum 36 January 24, 2001 22:10
