Mass flow rate at inlet and outlet are not equal |
Rep Power: 0 ![]() |
Hi. I am currently running Fluent on stator of turbine blade. During the simulation, the graphs on pressure and mass flow rate at inlet and outlet are experiencing repeat cosine graph after 6000 iterations. When I stop at simulation at 15000 iterations, I checked that the simulation is having the mass flow rate at outlet is negative and lower than that at inlet. Can anyone suggest to me what can I do to make the mass flow rate equal at inlet and outlet and how to solve the repeated cosine graphs?
Specify mass flow rate for periodic boundary conditions in channel flow | lion1990 | OpenFOAM Running, Solving & CFD | 1 | July 9, 2018 17:46 |
Outlet mass flow rate | xab | Fluent Multiphase | 2 | February 6, 2017 10:56 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Compressible flow, no data at the outlet | mireis | FLUENT | 6 | September 3, 2015 02:10 |
Mass flow inlet and pressure outlet issue | nikhil | FLUENT | 5 | December 11, 2013 12:30 |
