Journal interruption : non-blocking socket operation |
André
Rep Power: 10 ![]() |
So my batch operation which is reading from a journal file was interrupted (warning message), with the following error appearing on the console:
Last Error:A non-blocking socket operation could not be completed immediately. It happened when trying to save a data file, however it seemed like a sporadic error as it had written previous data files without a problem. Any ideas on how/what/why is causing this? I already have the batch options in the journal to close questions: /file/set-batch-options/ y n y n Thanks in advance for your help!
Sapere aude! |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
It's probably not a Fluent setting.
socket errors are comms errors, which could be anything. I guess it tried to write the data file and couldn't and spit out that error. |
André
I understand. Do you have any suspicions? Parallel processing? Network? Admin rights?
Thanks again!
Sapere aude! |
loading issue libraries:libsimpleFunctionObjects.so libsimpleSwakFunctionObjects.so | immortality | OpenFOAM Pre-Processing | 15 | April 7, 2024 12:35 |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 06:47 |
Incompatible dimensions for operation | ruben23 | OpenFOAM Running, Solving & CFD | 2 | June 12, 2015 04:14 |
999999 (../../src/mpsystem.c@1123):mpt_read: failed:errno = 11 | UDS_rambler | FLUENT | 2 | November 22, 2011 09:46 |
help needed about phase change | Yanhu Guo | Main CFD Forum | 4 | January 23, 2001 23:16 |
