Assessing Residual Plot
Old   January 5, 2019, 19:47
Default Assessing Residual Plot
danisnug is on a distinguished road
Good day,
I'm currently running a HVAC flow simulation inside bus cabin, the residual plot graph tends to converge but my graph is unlike the other. Other graph has smooth converging line while my graph has fluctuating line. Could you help me assessing what are the problems with my simulation? Provided here is an image of my residual plot.
Thank you
danisnug is offline   Reply With Quote
Old   January 6, 2019, 15:15
RaiderDoctor is on a distinguished road
Hey danisnug, welcome to the forum!
So, you're asking a question about convergence. Unfortunately, there really isn't a clear-cut answer as to whether your simulation is "good" or not. I'd recommend reading this (https://www.engineering.com/DesignSo...nvergence.aspx) to get you started. Then, I'd check out what some of the other smart dudes on this forum have posted (Convergence).
Finally, I don't think you're going to get much help on your problem, with the way you asked your question. Fluent is an immensely complicated program with a lot of customization options. When you ask a specific question, you need to post the specifics of your setup. For instance, is your case transient or steady-state, is there mesh motion, does something happen every few iterations that might cause the spike in residual activity, etc. Screenshots of your fluid domain, mesh, and options you selected are a big plus. That isn't necessarily an invitation to start posting now, I think the info I provided might help you better understand the nature of your simulation as is.
Good luck!
RaiderDoctor is offline   Reply With Quote
Segmentation fault when using reactingFOAM for Fluids Tommy Floessner OpenFOAM Running, Solving & CFD 4 April 22, 2018 12:30
chtMultiRegionSimpleFoam turbulent case Aditya Patil OpenFOAM Running, Solving & CFD 6 April 24, 2017 22:13
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 02:20
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 06:37
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
