Nicolo' Frisone
Rep Power: 7 ![]() |
Hi guys,
i'm studying with Ansys fluent (16.0 version) 4 different cases for driven cavity flow, the geometry is a square of 1.75m x 1.75m with an inlet and outlet of 0.5 m. i have to study: Re=10 Re=500 Re=10000 As Laminar flow, and the fourth one is with Re=10000 using the k-epsilon model for the turbulence. In order to have a significant velocity inlet for the Re=10 case, i chose as a fluid the engine-oil already present in the fluent database. I used a quadrilateral mesh first, but it gave me a reynolds cell number > 2 for the k-epsilon case, then i refined it along the walls using the bias factor and the problem disappeared. All the solutions goes to convergence using residuals with a order of magnitude of 10^-6, except for the Re=10000 Laminar case. Here the residuals don't diverge but they fluctuate around 10^-1 for continuity and 10^-3 for the velocity. I tried to decrease the urfs for pressure and momentum but it doesn't work,i tried to use a discretization at the first order for momentum, i also tried to refine the mesh again but it doesn't work, i don't understand how to solve this problem so i hope somebody can help me with this. |
driven cavity, high reynolds number, imhof, laminar flow |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 17:02 |
Lid Driven Cavity and Turbulent Flow | Mayzie12 | FLUENT | 1 | November 8, 2017 06:28 |
Limitations on time the step for lid driven cavity flow | ja0335 | Main CFD Forum | 12 | October 21, 2016 19:13 |
Flow over a cavity inconsistent | Sparow89 | FLUENT | 0 | June 20, 2016 12:02 |
Wrong Pressure countors for channel flow driven by mass flow rate or press gradient | ash-khan | FLUENT | 0 | June 21, 2009 10:02 |
