number of iteration in fluent
Old   December 22, 2018, 10:05
Default number of iteration in fluent
Weiqiang Liu
Weiqiang Liu is on a distinguished road
hello, all
I am doing a catalytic combustion of methane with fluent 17.0. The whole reaction set includes 340 gas phase reactions and 24 surface reactions.
the computation domain is two dimensional with 40000 cells. The case is steady state.
Now I am computing with 100000 iterations. the convergence standard is set as follows:
energy residual below 1e-6 and other residuals below 1e-3.
after 100000 iterations with 3 days of computing, all residual standards seemed reached the predefined value and some key parameters like temperature field, surface coverage of pt(s) are reasonable and continuous. however some other indexes like surface reaction rate of methane on the wall are discontinuous. I am wondering is the discontinuity due to having not converged.
can anybody give me some advice on how many iterations actually do I need on these similar cases according to your expertise.
thanks very much!
weiqiang
Weiqiang Liu is offline   Reply With Quote
Old   January 2, 2019, 10:41
sufjanst is on a distinguished road
I don't think that your number of iterations is the problem. 100000 iterations should be more than enough for this calculation.
A lot of parameters like the combustion model, turbulence model, URFs, solver settings or the mesh can affect the convergence.
sufjanst is offline   Reply With Quote
Old   January 2, 2019, 12:09
Weiqiang Liu
now I’ve had 400000 iterations already. I patched a 2000K temperature to the whole computation domain. The maximum temperature after 400000 iterations is 1260k. I use species transport model with laminar finite rate.
Now the residuals are still oscillating. The default results for convergence are 1e-6 for energy and 1e-3 for others. I found it’s not small enough. How do you usually judge convergence according to residuals regarding to chemical flow simulation.
Thanks
catalytic, convergence, methane combustion, number of iterations
decomposePar no field transfert Jeanp OpenFOAM Pre-Processing 3 June 18, 2022 13:01
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' BrendaEM OpenFOAM Meshing & Mesh Conversion 12 April 3, 2022 19:32
Inconsistencies in reading .dat file during run time in new injection model Scram_1 OpenFOAM 0 March 23, 2018 23:29
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 14:38
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
