Modelling combustion using species transport
Old   December 19, 2018, 21:55
Default Modelling combustion using species transport
Anshuman Sinha
Anshs is on a distinguished road
I am modelling the combustion reaction of CO gas with Oxygen, using the species transport model. It is a non-premixed type combustion, where the fuel gas ( CO) enters the reactor at 1700K and oxygen enters through a jet at 300K . Oxygen and fuel CO burn to make CO2 gas in the reactor.
My problem is that :
The product gas CO2 is being made but there is no rise in the temperature.
I have defined my own mixture template, and not using the predefined ones.
I have defined the reaction according to it's stoichiometry and kinetics.
Currently the Cp is set to constant 1000, ( as seen by me in one video of non-premixed combustion of CH4 gas )
The maximum temperature stays to 1700K, which is indeed the inlet fuel temperature ( fuel = CO ).
I know that there is a problem in setting the properties value, as a function of temperature . Like that of Cp, viscosity, thermal conductivity etc. I tried searching for them, I got the relations of Cp as a function of temp. in polynomial form. e.g : a + bT +cT^-2 ; now how to put the T^-2 in the polynomial entry for Cp. Since it only gives T^+2 not T^-2.
Secondly, since I have to encounter a wall reaction as well. I am not allowed to use the eddy dissipation model. Thus I am using the eddy dissipation/ finite rate model. Can someone tell me the difference between these two and why can't wall reaction be accommodated there ?
Finally, I want to learn about the changes that would happen if I change the diffusivity, viscosity, thermal conductivity from constant to ideal-gas mixed etc.
Last edited by Anshs; December 20, 2018 at 20:09. Reason: Nobody is helping me and answering my doubt, I'm stuck on this problem from 2 weeks
Anshs is offline   Reply With Quote
combustion, species tranport
Combustion modelling in OpenFOAM - Difficulties AleDR OpenFOAM Running, Solving & CFD 23 January 31, 2021 00:40
Direct numerical simulation of species transport equation with phase change Pmaroul Main CFD Forum 2 October 12, 2018 17:02
Modelling Combustion in Porous Zone tanjinjack FLUENT 2 September 26, 2016 05:10
Diff in Combustion Modelling By Species Transport Model & Non-Premixed Combustion bhanuday.sharma FLUENT 0 June 23, 2015 03:50
A question about species box of species transport model tjushang FLUENT 2 June 25, 2014 08:56
