calculation speed of fluent
Old   December 19, 2018, 11:36
Default calculation speed of fluent
Weiqiang Liu
Weiqiang Liu is on a distinguished road
hello all,
I have a question of computation speed with fluent. The specification of my desk top is AMD Ryzen 7 1700X eight core processor and 8 GB ram. When I calculate methane catalytic combustion with detail mechanism, the iteration is very slow.
however, the usage of CPU and RAM is not very high while computing. Can anybody give me some suggestion?
by the way, I am using series solver of fluent.
thanks
weiqiang
Weiqiang Liu is offline   Reply With Quote
Old   December 19, 2018, 11:41
Lucky
The serial solver uses only 1 process so your other 7 processors will be idle. Run parallel with 8. You only occupy as much RAM as your calculation needs. You can only check the usage of RAM capacity, not bandwidth so it's difficult to know if the RAM is being underutilized unless you run a really big problem.
Old   December 19, 2018, 11:42
Weiqiang Liu
ok, I get it. thanks very much
Old   December 19, 2018, 14:36
Weiqiang Liu
you're amazing. you even know the number of cores of my computer!!!
cpu usage, detailed mechanism, iteration speed
How to connect calculation in Matlab with calculation Fluent Fany FLUENT 6 May 11, 2017 17:50
Counsel: Airfoil Fluent In-compressible Low Speed Wingman CFD Freelancers 2 November 15, 2016 13:18
ansys fluent v16.0 :problem whit resume calculation and automatic export file ca3tiel FLUENT 0 May 29, 2016 20:08
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
Update on Fluent 12 calculation speed Allan Walsh FLUENT 2 May 23, 2008 13:21
