Generating Cd vs. Mach # Report in Fluent
Old   December 16, 2018, 17:34
Question Generating Cd vs. Mach # Report in Fluent
Nabeel Sherazi
nabeelsherazi is on a distinguished road
Hi guys,
First post here so sorry if I commit any etiquette faux-pas. I'm a student trying to learn Fluent and struggling with the graph I want to generate.
So far, I have learned how to get my airfoil geometry into Fluent and generate a mesh. The pressure and velocity diagrams all look good, but I'm struggling with how to use the reports feature to make a coefficient of drag vs. Mach number XY plot.
In Fluent, I made my far-field boundary condition velocity a parameter, so that I could hopefully iterate through it to make the graph. I also set a report definition that outputs the coefficient of drag when I click calculate. However, the only way I have found so far to calculate it quickly for many values is to change the parameter by hand in Workbench and click "Update Design Points," which then lists the new C_d. I have been moving them by hand into Excel.
I'm certain there's a better way to do this, and would be very grateful if someone had some advice on how to approach this problem. I have read the Fluent documentation several times, but it doesn't cover making reports in this way at all.
Thank you so much for reading.
nabeelsherazi is offline   Reply With Quote
Old   December 17, 2018, 08:49
Lucky
Fluent won't generate the drag coefficient vs Mach number plot. What you have is working as intended.
You are probably 90% of the way there. You can make this report/monitor otuput to a text file (how to do this differs slightly between versions) and then smartly read them into excel using some VBA coding for many cases. The last thing to do is set up a script to smartly run all the cases in Fluent without manually clicking the run button in workbench. To automate all this requires quite a bit of learning. It may or may not be faster to keep doing it manually.
Old   December 17, 2018, 22:30
Nabeel Sherazi
Ahhh... a bummer, but good to know that I was on the right track. Now my efforts feels less misguided
Thanks so much LuckyTran for your help! I appreciate it very much
fluent, mach number, parameter set, reports
The low mach number approximation in fluent Jamie FLUENT 5 October 7, 2015 10:15
Doxygen documentation Tanay OpenFOAM Installation 9 September 23, 2011 12:40
HOw to match the Mach number in FLUENT?? applemango Main CFD Forum 0 April 20, 2010 07:34
Fluent Force Report maharvey FLUENT 2 April 12, 2010 14:06
Fluent Report yeo FLUENT 0 February 21, 2003 09:31
