Changing Temperatures in a Particular Region in the Flow Field |
December 15, 2018, 22:23 |
Tacettin Utku SÜER
Rep Power: 11 |
I want to change temperatures according to a correlation in a particular region (cylinder, sphere) in the flow field. An idea came to my mind with the energy source term, but I don't know if this is possible. I do not think of any other method.
I would be very glad if you could help. |
December 16, 2018, 00:45 |
Lucky
Rep Power: 66 |
It would have to be an energy source, yup.
Unless you separate it as a different cell zone and apply fixed values and use that to fix the temperature in region. |
December 22, 2018, 06:42 |
Tacettin Utku SÜER
Rep Power: 11 |
Thank you for your answer but we solved the problem in a different way. The data was written out as text file (.ip) and then the data was changed in the MATLAB. Finally, the processed data was restored (Read and Interpolate). But this process is challenging and takes a long time. We have to repeat this process periodically. So can we use UDF or anything else to do the process automatically?
change temperature, energy source term |
Non-zero mass flow rate for a confined region and bizarre vector field at wall | appotoxin | FLUENT | 0 | May 28, 2017 02:02 |
problems of solving the flow field using Openfoam | marialhm | OpenFOAM Running, Solving & CFD | 0 | April 12, 2017 07:56 |
Setting boundary conditions for simple pipe flow with flow direction changing in time | Sipher | FLUENT | 1 | May 4, 2015 21:05 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 14:12 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 05:38 |
