Is it possible to have an actual velocity profile at the inlet with pressure-inlet BC |
December 15, 2018, 02:04 |
hanis izzati
Rep Power: 8 |
I am doing research on airflow condition in airways. Is it possible if I set the inlet's boundary condition as pressure-inlet but at the same time I want to achieve a fully developed flow (actual velocity profile) right at the inlet without having to extend the inlet? Before this, I set the inlet as a velocity-inlet and I used UDF to get actual velocity at the inlet.
I am very grateful if someone could give their opinion on this matter. Thank you in advance. |
December 15, 2018, 18:10 |
Lucky
Rep Power: 66 |
You can, but not in the way you are thinking. You can't specify static pressure and velocity at the inlet because that would imply the inlet is supersonic. You're trying to do something that violates physics. Don't use a physics based solver if that's what you want to do.
December 16, 2018, 21:48 |
hanis izzati
Rep Power: 8 |
Thank you for your opinion. I really appreciate it since I am not sure about it
actual velocity, boundary condition, pressure-inlet |
3d velocity profile at velocity inlet | swethaprakash | FLUENT | 3 | September 1, 2015 03:10 |
extracting outlet velocity profile from one case to another case's inlet | tonggysun | OpenFOAM | 2 | September 13, 2013 05:19 |
Why we normally provide velocity at inlet and pressure at outlet for pipe flow? | p07ip705 | Main CFD Forum | 3 | August 3, 2012 06:53 |
FSI- Pipe- uniform velocity profile inlet | Absy | Main CFD Forum | 0 | April 6, 2010 04:01 |
Pressure Inlet Velocity | prapanj | OpenFOAM | 11 | June 23, 2009 12:15 |
