Error: "MPI Application rank 0 exited before MPI_finalization() with status 2"?
Old   December 9, 2018, 11:13
Question Error: "MPI Application rank 0 exited before MPI_finalization() with status 2"?
malekan.cfd is on a distinguished road
Dear all,
I have a Fluent problem where I defined material properties using a simple UDF, like:
DEFINE_PROPERTY(thermal_conductivity,cell,thread)
real tc, T;
T = C_T(cell,thread);
if(T <= 300)
tc = 1;
else
tc = 2;
return tc;
When I use this UDF, I have got this error: "MPI Application rank 0 exited before MPI_finalization() with status 2". Can anybody five me ant advice how to solve this error please!
My model works fine without UDF.
Thanks,
Malekan
malekan.cfd is offline   Reply With Quote
Old   December 9, 2018, 23:53
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
did you put
#include "udf.h"
in the header of your UDF?
best regards
AlexanderZ is offline   Reply With Quote
Old   December 10, 2018, 10:02
Default Yes, I did
Yes , I did that. In fact, compilation part of the code does not have any problem. When I try to initialize the problem, I receive that error.
Best,
Old   December 10, 2018, 20:58
Alexander
Try to initialize first, than load UDF
best regards
Old   December 12, 2018, 10:14
Default Initialization needs udfs
I need udfs to define material properties, how can I do initialization without loading udfs?
Old   December 12, 2018, 11:14
Lucky
You don't need material properties to initialize anything
Old   June 10, 2019, 23:14
Etienne Lin
hongzhilin is on a distinguished road
I've had the same error when using fluent in workbench. I was trying FSI and the coupling interface shows this error.
My solution is to delete the fluent module and reset a case. Though the same problem occurred after several times of interrupt and restart, once all parameters are determined and the case is reset, the program also works.
hongzhilin is offline   Reply With Quote
error fluent workbench, fluent, udf code
mpt_connect: errorThe fl process could not be started. MPI Application rank 0 exited tjZDH FLUENT 3 November 28, 2021 15:30
Ansys Licence Serve on Ubuntu 16.04 LTS david.pasquale ANSYS 2 January 20, 2017 12:52
MPI application rank 0 exited before.. jypark FLUENT 1 July 15, 2016 13:58
MPI Application rank 0 exited before MPI_Finalize() with status 1 mustafadeniz89 AVL FIRE 6 November 24, 2015 10:40
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 15:53
